I have a 2001 ML320, for the past few months my BAS/ESP light turns on while driving which causes accelerator to stop working which leaves me coasting to find a place to stop the car so I can turn off/on the car to "fix" the problem.
I'm wondering if the recall issued in 2011 regarding the cruise control/brake light switch applies to this problem.
02 ML320 06 ML500
Your problem is probably being caused by a mal-adjusted brake light switch. Remove the connector to the Brake light Sw. and then follow the instructions for removal and installation. If the problem continues replace the switch using the same instructions.
