SL350
Hi guys, just bought an ML270 CDI, 2003 facelift model. I've noticed there is a fault with the headlight stalk in that, the main beam trigger seems to have a mind of its own and will flick between main beam and low beam on its own. Anyone else come across this? if so any idea on a fix?
SL350
Discussion Starter #2
Anyone???
Noticed today that the side lights have stay on by themselves at times too even with the switch at position "0"
ML55 2003, ML55 2002, ML63 2007
Check the relay in the fuse box. Change it with a similar one from the box for diagnostic purposes. If your problem is fixed by changing the relay buy a new one and replace.
