I was looking for any possible reason my engine was idling high and shaking quite violently at idle. (I found out I had an open vacuum port on the intake manifold where the tube to the smog valve was disconnected.) One place I looked was to see if there were any burnt marks inside the distributor. Under the distributor rotor and dust cap, I noticed there are small weights. I think they're for advancing the rotor at higher RPMs. Above one of them is a spring that would hold the rotor in the lower RPM position, but it looks like there should be two springs doing that. Without that second spring, my rotor could be advancing too soon. (And the dizzy could be slightly off balance) Can anyone confirm whether there are supposed to be two and if those springs come in different tensions? Image here.
