Hi guys, just latley the car has started to miss fire for no aparent reason, some times its ok, sometimes im strugling to get to work? ive read storys of mass air sencer , etc but have you guys , got any other idears .
regards.:mad:
C9H9N Offensive Odor Exuder
2002 ML320, 2005 S430 4MATIC RIP, 2010 F150 Crew Cab
Sensors usually throw a code that lights up the check engine light. You simply may have bad plugs or plug wires. I have 152,000 miles on my plugs and wires! So far, everything is A-okay! My mechanic checked the plugs last year and he was amazed at how clean they were!
Thanks for the reply, its not lighting up the check lights but ill check the pl.ugs and leads .:(
ive got a feeling, that i might of put, crap fuel in,as i seemed to get alot more than normal, is it easy to empty the fuel tank?
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
Well, to empty the tank on my ML, I simply fully depress that control lever just to the right of the brake pedal. :p
