1 - 20 of 20 Posts
hi all i have S63 AMG and have misfire detected on 5 6 7 8
spark plugs new
coils news
timing chain checked with tools
ecu tested with other
O2 sensor brand news
car checked and good ( both )
i dont know on how to resolve it
i bank is white and one is black ( color en spark )
thanks if you have idea
1998 MB E300TD, 1997 MB E36 AMG, 2001 MB E55 AMG. 2011 BMW 335d
Take out o2 sensor and start car.
Discussion Starter · #6 ·
cld start i have 8 ok for 10 15sec 1100rpm and after 4 cyl and 750rmp
Did you take out the O2 sensor before cat and started car?
Any codes beside the misfire?
Not unplug. Physically remove the sensor from the exhaust.
Then it's either ECU or bad catalyst converter.
Discussion Starter · #14 ·
l'ecu n'est pas possible car le démarrage à froid j'ai 8 cylindres pendant 10 secondes et après cela seulement 4
une rangée de bougies blanches et l'autre noire, pas d'étincelle
i will try to make CAT off with my KESS
English please. I can't read french.
Discussion Starter · #17 ·
ecu is not possible because during 10sec at cold start i have 8 cyl
one range is white and on i white ( spark plugs )
That is not conclusive. Could still be bad ECU, just because the car runs good for 10 sec doesn't mean it's good ECU.
'71 Pinto
Suggestions:
If are not already doing so use Xentry (MB diagnostics). You have done several already here is a basic list of steps to consider. In addition, attached bulletin containing additional procedures although it was released for different engine apply same suggested remedies for your vehicle.
  • check for signs of external oil loss
  • check exhaust gases (blue smoke)
  • perform short test with freeze frame data
  • perform compression and leak-down tests
  • check spark plugs
  • bore scope cylinders
  • check O2 sensors, turbos, cats, exhaust components
1 - 20 of 20 Posts
