1 - 16 of 16 Posts
1979 280CE
Once again while I have the door panel off I need to replace the seal that the window rolls up in the middle of the two seals on the outside mirror(not dew wipes). I will try to get a picture soon.
1979 280CE
Discussion Starter #2
The arrow is pointing to it
Mercedes 300te
Not sure if you asking directions to remove the sidemirror too?
Anyways, There is a small tab at the back end of the sidemirror handle use a small screwdriver to slide it down & pull out to remove. Can't remember if the chrome for the coupes are one piece or not.. I think they are..
There should be screws inside the door panels holes.. Most likely two 10mm bolts peek through the holes in the door. You should find it.. Hope this helps...
1979 280CE
All I wan to do is replace the seals. I thought you had to remove the mirror to do so. If you don't please tell me how to replace the seals.
1979 280CE
c'mon. anyone know?
1982 300CD
I got the mirror off, that's no big deal after you remove the arm, like euroamg said. And, the chromed plastic plate inside just pops off. But, that chrome triangle on the door is a PITA. Maybe I was a little cautious, but I never did figure out how to remove it. I'm pretty sure it should come off in order to replace that worn seal.
I was thinking of just covering it with some sort of rubbery coating. Maybe silicone or a few thick coats of acrylic paint. I might give it another try next time I have the door panel off.
Mercedes 300te
This a side mirror of a 450sl. They might be similar...
Last pic the seal is out.. It just slides out of the chrome frame.. Remember pics just for reference..
I don't think you have to remove the metal chrome triangle piece?
The one on the 450sl mirror the seal just slides out...
1979 280CE
I started to pull it out but I had second thoughts about it. When I started to pull it it looked like there was a metal plate the had rusted out and started to crumble. The plate was on the inside of the mirror right behind the plastic plate.
Could someone give me step-by-step directions on how to remove the mirror?
1982 300CD
One piece at a time.
Start with the adjustment handle, then pop off the silvery plate. I think there are screws under that holding the mirror to the door. Don't remember exactly now, but not that complicated really. There aren't any tricks, just have to roll up your sleeves and do it.
1979 280CE
Discussion Starter #12
Do I have to remove the mirror to replace the guide seals.
1986 300E, 1978 280CE
slides out
on my coupe the seals just slide out - must have been glued in at one time but now they don't always want to stay in place. I'm not sure because I don't see anything in the manual.
John
1979 280CE
Discussion Starter #14
Alright well I guess I will go ahead and try to pull them out and put new ones in.
1979 280CE
Discussion Starter #16
Gregs300CD, Today I looked alittle more into it and found that they are glued in. I'm going to order a couple this week sometime and put them in.
Thanks, JamieK for the parts number.
1 - 16 of 16 Posts
