Does anybody know how to make the LED lights on those aftermarket mirror covers you buy off ebay work? Do i have to wire it to the same wire as the side markers? Does anybody have any procedures on how to do this, like removing the mirror cover and side markers and how to wire them together? I bought my ML and the guy before me had these ebay mirror covers on it already but he didn't get it wired. Thanks
If you search it...the answers will come...
What you would have to do is of course run two wires for each side. To accomplish this you will have to run the wires from the mirror down through the door and through the harness connector sleeve and out through each kick panel. For the driver's side, either tap off the green wire to the left tail light signal bulb or the green wire on the front signal bulb in headlight housing. The other wire must be to ground.
Do the same for the right side, but the wire color is pink.
