1 - 11 of 11 Posts
2004 SL600; 2004 SL500; 2003 ML350; 1997 C280 Sport; 1987 190e 2.3 16v; 1986 190e 2.3 16V;
Not from one of my MLs, but from my old 2001 210 E430. Took some planning to get to this pic.
Sold the car at about 365,000 miles. I saw it running around town for a couple years, but then no more.
ps - changed the oil when fss said to, usually at about 17,000-18,000 mile interval, for those of you that insist on 3,000 mile oil changes...
2000 E 320 Wagon + 2002 ML 500 SUV
Merzatt, Springer:
You guys are inspiring me to hang in there. Our ML500 is a baby in comparison with only 160k !
So many more miles left IF I can lick this ABS / ESP / BAS issue.
Keep on truckin !
David in Texas
ML320 2002
Here's Millie ! Still running great. Change my oil every 10,000 miles using Liquid-Moly 5W40. Just had her hood repainted and she is looking good !!
Wasn't your 98 green?
I would like to have the good looking silver car in the background.
ML320 2002
My 200k list....
  • Flush tranny fluid
  • Change TC oil
  • Change coolant
  • Replace belt tensioner (noisy) and belt
  • Replace fuel filter (if I am feeling lucky that day)
  • Fix the popping rust spots
  • Replace spark plugs and test the wires
  • Fix the valve cover leaks
  • Stiff power steering during parking. ? replace P/S pump
05 500
Merzatt, Springer:
Keep on truckin !
David in Texas
ESP/BAS/ABS lights showing up is as old as the W163 ML is - it’s a non-issue, and the long timers can attest to that. A lot of us have “fixed” just to have them lights pop up again. Don’t worry about it. If it shows up, test you braking system in a secluded open area. Chances are that you’ll find out that your brakes work just fine.
Darkmann:
For me, it was back in Jan / Feb, just a nuisance occationally lit 3 lights. Then beeping came on. Then I made a change - 3 new VSS installed, then lights, beeping & limp mode. Now, not minor - no drive for 90+ days.
(Got reaquainted with my 12 Valve Cummins Ram truck - shes Analog doesn't quit)
Here's the post where I lay out what I belive is the root cause: Wrong sensors for my Chassis #.
They switched sensor design mid-2002 and new won't work with old, apparently.
This is extremely rare, my research suggests.
Saw one other guy - a youngster in Europe who had same issue & resolved after prior owner installed 3 'late sensors' when early were called for.
Reading his thread clued me into my root cause.
I won't KNOW 100% until new sensors arrive. But my 'Columbo moment' happened yesterday.
I plan to leave a Resolution Trail and a YouTube on this issue to benefit others.
Cheers - David in Texas
1 - 11 of 11 Posts
