Hi, I know people say use premium gas. I have been using 89(mid-grade). Gas is very expensive here in Vancouver BC Canada. I have nothing to worry about right? Cost me $65+ to fill the tank with 89. 91 would be insane.
Makes sense, the 89 has ethanol and although it's detrimental to milage, it's likely to make the engine happier in winterMine runs fine on either. Actually I notice it runs better on 91 in the summer and better on 89 in the winter. Must be the additives in the blends.
Sound fair. But did anyone got major problem by using Octane 87 all the way? Is there any expert in these stuff that can give me a good answer?In my area we have 87, 89 & 93. My C230 manual recommends 91 so I've been using 93. My former car, Altima 3.5 SE recommended 89 ocatane and I tried running a few tanks of 87 through it. Ended up with an O2 sensor failure and rough running. Switched back to 89 after replacing the O2 and I had no further problems.
IMO, if you're going to spend the extra money to buy a higher performance car that requires higher octane fuel then spending another $.10 per gallon should not be a big problem and could forestall big problems later on.
This is an old subject.....The expert is "gregs210". Search for many more premium fuel posts in Benzworld and see what they say also.........Sound fair. But did anyone got major problem by using Octane 87 all the way? Is there any expert in these stuff that can give me a good answer?
In long term (let say 5 years), if you use Octane 87 versus mix of Octane 89/91, you will save lot .....
Mike, w.t.h you talking about I'm RONThe engine needs 95 RON. 89 Pump Octane is about the same as 94 RON. So it's very close, could be OK. 91 Pump is about 96 RON...could mix it 50-50 to be sure you're meeting the minimum standard. The compression ratio is really high.
