Hi, There is a Metal Friction Noise coming from my rear Brakes. It’s not the first time I have this issue for more than a year. I complain about that much time to the dealer workshop and every time they readjust the brakes and clean. Which not solving the problem I told them check the rear break cylinder it may not releases after applying a brakes and may that was the resone where I change my rear brakes pad twice with the front one . where in usually almost of the car consume the front pads first . The service advisers said “ sir this is because ML is a heavy car and it’s brake performance is so high and the ABS apply on all wheel SO it’s normal for that where the Rear brake run faster than the front one “ It’s not coming since ? My friend got Dodge Durango which is much higher than ML and he say I replace my rear one after three time replacing the front one. I thing the Service adviser can’t diagnose the problem. And idea of same problem in ML and how to solve it. Thanks
