1 - 18 of 18 Posts
Hello,
I started this project after i was done with my laptimer project. Now almost 6 months later i got a working unit now with a new LCD unit.
This means no more bleeding ATA Displays, but a nice new one with the correct temperature on it.
See the pictures.
Sofar its working on those:
All W201 W124 W126 R129 and so on
Check the pictures, its just like the original one, but this screen wont start bleeding for the next 20 years.
For more information you can Pb me or sending me an email.
Greetings
Marcel
1987 190D 2.5 Turbo
Nice! Mine is blacked out. Been looking for a replacement unit, but I have heard that in 1987 there could be a 3 4 or 5 pin plug on the unit, so I would rather just fix the actual LCD.
1993 MB 400SEL; 1986 190E 2.3-16 w/ MS II EFI
My temp display missing some segments. Hopefully it is just the LCD and not the actual board itself. Do you have replacement for *Fahrenheit?
'87--190E 2.3-16v(being rebuilt), '99--C230 Kompressor
i've never had issues with the temp display going out, mine has always been reading the correct temperature regardless of what components i replace
although i would suggest the OP do a DIY for those on here instead of trying to price gouge for close to $50 a pop it's a screen replacement, it's not K-jetronic
Discussion Starter · #7 ·
After a few years i found my old topic.
To confirm i have made the the screens for the W124,w126,R129,W201 that share the same design Outside temperature LCD unit in the car.
Since 2012 i have made this part and its like a oem replacement and 100% correct and working.
If interested please lett me know, both celcius and fahrenheit for all the models see some pictures
2666340
2666341
2666342
2666343
2666344
2012 GLK350, 2012 E350 Cabrio, 1988 560SEC - "Johnny" (ex-Johnny Carson owned)
I have a 1988 560 SEC (USA Spec). Do you have to disassemble the dash to get to the LCD? how do you think it will take to change the display on the first attempt? Do you make these displays yourself? Can you ship to the USA and how much do they cost?
If interested please lett me know, both celcius and fahrenheit for all the models see some pictures View attachment 2666340 View attachment 2666341 View attachment 2666342 View attachment 2666343 View attachment 2666344
Yes i have made those myself, back in 2014 when i started those, till today all working at my clients and also on my own cars i fitted my work :)
To get the unit out, just pull the cluster out of the dashboard. then unplug the connector on the back of the unit see picture and remove 2 small screws, then take out the unit from behind.
Yes i ship world wide not a problem, just send me a PM with your details
2704049
1989 190e 2.6
As a note on this, when I pulled my cluster I found a white wire coming from the LCD on my 89 190e. This wire didnt have a connector and I had to cut it to remove the cluster. Turns out this wire is for a speed sensor for the outside temp display. Just an FYI if you run into the same. I did not reconnected the white wire and when idling my outside temps runs way high. I'm going to toss a couple connectors on that wire next time I have the cluster out.
Discussion Starter · #12 ·
Yes thats for the speed... all new models from 88 and up have this option :) and they mostly all share the 6 pin lcd version aswell. if needed more info PM me.
Discussion Starter · #13 ·
You have to turn on Private message so i can send you a message about this :)
Marcel, hope you are doing well….I just bought a 1987 560SEL and I need to replace the temp display. I would like to order one of yours but I can’t figure out how to PM you…. Can you PM me and I will reply? Thx.
· Super Moderator
1986/1990 W126
Welcome to the forum. You'll need to build up a few posts before the message function is activated.
When you get time please do fill out your profile for us with model and year. Enjoy!
1 - 18 of 18 Posts
