1 - 1 of 1 Posts
Hi. Can anyone help me with my air suspension? Been trying to fix system for a while but I have come to a halt and need some ideas. Currently I have a warning light on the dash.If you keep your finger on for 2 secs it flashs then remains lit.This I have discovered means I have a permenant fault that needs sorting. Took it to Mercedes. They tested it and said" Fault with transverse Lock Valve & release valve current." Purchased new release valves and fitted them and still have same fault. I replaced pump assembly 6 months previous so don't think its this as powered to 12v it pumps! It has been suggested to me that the fault codes need clearing as the system is in shutdown. Several diagnostics companies have tried to connect to it but have failed.One garage suggested Mercedes may have locked access to management system.Is this possible?
Any help would be much appriciated Thanks
1 - 1 of 1 Posts
