Dear mercedes people
i hope someone can help. i have a sprinter and when i put the side lights on all the lights internally work as they should. When i put main beam on the dashboard lights go out incliding the speed display indicator and all the intruments and also the light for the controls beside the drivers all the lights go out on them too. i checked the display board and that looks ok. i dont really want to pay for a new steering wheel control assembly unless it is what it is. is there anywhere else i should try. and also the alternator is ok.,
W221 & Audio Moderator
Not ignoring you, pehbond; I just don't know enough about the Sprinter to give you a good answer.
Where are you located, and what is the model year? Perhaps someone with a similar model will be able to help.
It is an 05 plate sprinter minibus. It has a twist arm for the lights. The connection into the dash looks ok. I still have to check the feed though from the control to the dash
