Mercedes ML 3.2 1998, Mercedes w124 250D 92'
On the drivers side, under the hood, there are ground connections near the windshield in the ML nearby the brake fluid reservoir and so are those on the drivers side nearby the battery. In my ML one of those ground connections nearest this brake fluid reservoir is not connected, or just factory left as a provision? My question is does anyone have any idea or a photo showing the proper wire ground connection to that provision nearest this brake fluid tank, what device would be grounded therein?
2000 ML430 (Sold)
In mine there are three. One near the battery, one beside the coolant tank, and one beside the brake fluid tank. The one beside the brake fluid tank to which you are referring appears to have the ground from the main fuse box running to it.
Sent from my GT-I9000M using AutoGuide.Com Free App
