1 - 1 of 1 Posts
A124 W124 C124
W124 MERCEDES E320 UPDATED ENGINE WIRING HARNESS DELPHI #124 440 5632
E320 Harness #124 440 5632 on eBay
MERCEDES E320 ENGINE WIRING HARNESS OEM DELPHI #124 440 5632
THIS OEM UPDATED HARNESS WAS CAREFULLY REMOVED FROM A NON-RUNNING 1994 E320 WITH 158K MILES. CHECK THE EPC OR YOUR DEALER FOR COMPATIBILITY.
SINCE IT WAS NOT TESTED ON A RUNNING CAR, IT HAS A LOW STARTING PRICE. THE CONNECTORS AND INSULATION APPEAR TO BE IN GOOD CONDITION. THE INTAKE AIR TEMP SENSOR PLUG, HOWEVER, IS MISSING (CUT OFF) SO YOU WILL HAVE TO SPLICE ONE IN.
ORIGINAL BIODEGRADEABLE HARNESSES MAY HAVE DETERIORATED INSULATION HIDDEN UNDER THE PLASTIC SHEATHING WHICH CAUSE INTERMITTENT ELECTRICAL PROBLEMS.
THIS REPLACEMENT HARNESS WAS DESIGNED TO SOLVE THIS PROBLEM
YOU SHOULD ALSO REPLACE THE STARTER/OIL LEVEL & PRESSURE SENDER HARNESS BECAUSE IT ALSO HAS BIODEGRADEABLE INSULATION.
1 - 1 of 1 Posts
