Hii!! I'm italian and i not speak a good english , sorry for my errors...
In my car i have change:
1) Rotor and distributor ignition ( ignition cables, air filter, benz filter , oil filter)
2) Alternator (new);
3) Fuel distributor (new);
4) Throttle valve with swicth (used);
5) Fuel injecotor (new)
6) All air pipes-gasket; ( new)
7) Cold injecotor ( used);
8) ECU ( used) (but my ECU is good, i have try to change);
9) RELE' OVP (NEW);
10) Air sensor ( tath is in front to the pipe aspiration) ;
11) 2 FUEL PUMP (new).
12) Idle valve (new)
13) Air flow meter.
The problem is this:
If i try to start cold engine ( for the firt time of day , or if it's been several hours since the last starting), i must turn on the key for 4-5 seconds. ;low months ago , when I changed all the pieces of the injection the engine started even when it cold with 1/2 turn of key!!!
when i start engine : Idle is low for one second, it after up to 900-1000 rpm ,so when engine warm up, idle drecrease to 650 rpm. I know that's correct! But at firt once i press accellerator (after firt engine start), the idle stay at 1200-1300rpm(also i release the accelerator) for 5 seconds , after , it decrease to 650 rpm.
In the running Idle stay always at 650 rpm but engine have low vibration.
During first start, after leaving the engine running for just a second , if i turning off the engine and start it , the engine turn on with 1/2 turn of key.
I thinck i have a cable problem..... what you mean??
Thancks
9) RELE' OVP (NEW);
13) Air flow meter.
Thancks
