21 - 40 of 51 Posts
87' 190E 16V / 93' 600SL / 02' G500
Ambitious project. Just be cautious with adding that much weight to the front end as its going to throw the handling way out. I drove a Monster Miata (302 V8 in place of the 4 cyl) it was great in a straight line but under steered like crazy making it an irritating thing to drive. Definitely interested in how you make out.
Mercedes 600 sel 1993 Mercedes 190 2.0 1984
Discussion Starter #22
thanks!!
can't say anything about that yet but the weight is not al just on the front axle added the gearbox will be about 30cm more back then the end of the original gearbox so also the weight is behing the front axle
it will be heavier offcourse but i suspect the weight to be below 1300kg oem 2.6 automatic is 1200kg so it is still a light car i thinks
so we will see
i will also go for wider tyres in the front to 235
The definite idea is to get as much weight behind the front axle as possible. Perhaps put a couple of cement bags under the back seat.. ;) Again my hats off to you on a great project.
Discussion Starter #24
new interior found en subframe ready
so the last weeks i work on the radiator build in and the subframe is done also i have build in the
w210 steering housing
and found a leder 2.3 16v interior
Discussion Starter #25
engine is in the car
got the engine in the engine bay and it fits pretty good
i got enough room in between the engine and radiator
also in the back of the engine there is still some room to put
the oem interior fan cover back with some modifications
the fan will be placed on the place of the battery
because the cover needs to be moved about 3 TO 4 CM to
the firewall
also very important the hood will close without any problems
W201, W212, W221, & W222 Moderator
'84 Euro 500SE, '85 Euro 2.3-16, '51 Euro 170S, '97 Jeep Wrangler Sport, '15 G63 AMG
This is pretty awesome!!
Mercedes-Benz 190E 2.6, 300E, Volkswagen Jetta 1.4T
At first I was skeptical about this project, but you are making good progress. Nice work.
92 300CE/1996 mustang cobra (supercharged)/12 Civic/15 F150/04 F150 mud truck
you dont "need" power steering- dont let that hinder your progress.
my 83 porsche 944 didnt have it and it was an awesome car to drive.
you deserve the "modification of the year" award for this project.
well done and keep us posted.
Discussion Starter #30
your right it can be driven without it
i have the steeringbox build it and als the pump is mounted back on the engine and as far
as it is looking right it will fit and work
Discussion Starter #31
engine mounts done and interior fan re-placed
so got the new engine mounts made and welded new mounting plates in the chassis
also got the interior fan replaced to generate some extra space on the back side of the engine.
next thing will be the transmission build in
here is the video
Discussion Starter #32
so i got a update
took me a little longer then i wanted
i have also the transmission mounted now
the transmission is modified a little
also the tunnel is raised 3 cm to get the transmission fully free
in the tunnel
here is the video
Discussion Starter #33
started on the rear suspension and subframe mods
so I got some work done
got the steeringbox dropped so it will not hit the oilsump anymore
also got the steeringbox connected again to the steeringwheel.
most of the work in the enginebay is done. I got to place the transmission cooler but first need the front bumper for it. I don't have it yet.
and alos need to do some mods to the front suspension top mounts because I'm going to swap to coil overs front and back.
I have the full rear suspension and subframe dropped and dismantled also the donor s600 subframe is a part.
I'm going to use the diff axles and wheelhubs from the s600 in the 190 rear suspensions so need to sort out some thing to make it fit and work good
here is the video
2004 SL600; 2004 SL500; 2003 ML350; 1997 C280 Sport; 1987 190e 2.3 16v; 1986 190e 2.3 16V;
Bump - any updates?
Discussion Starter #36
rear subframe and rear suspension is done
Bump - any updates?
yes I got some updates
I got the rear subframe modified and the bigger s600 diff mounted
als I'm using different rear hubs to fit the s5600 axles
and I have done a modification to the rear suspension so I can dit coil overs in the back to have
more control over ride hide and suspension settings
Two months since last update - have you had time to work on it at all?
Discussion Starter #38
front suspension done
yes i got some work done but had some busy weeks
i have been busy on the front suspension
coil overs are build in now also the
drive shaft is on it's way
it is been shortend about 50 cm
also the rear axles are going to be shortend
by 5.8cm
also got a facelift bumper kit
here is the video
Awesome stuff! Thanks for the time taking these videos!
I think I missed it but what are you using for a steering gearbox?
21 - 40 of 51 Posts
