@pablo_can Hopefully you'll find the issue soon then.thank you, but this is not the case for most of us. my coolant level is ok, but I have this problem still.
The purge valve is on the inlet manifold, hiding behind the air filter box.Where is PURGE VALVE or what ever is that thing what makes ticking, stop for moment and starts again, lot more silent after cleaning that intake bridge valve but thinking that is related to acceleration vibration, because vibration wont come in every acceleration, or maybe it could be dirty fuel nozzle, by the way i have B170 and spark plugs, filters, oils and both shafts and one front bearing is changed.
I have manual, forget to mention, but i will check purge valve and hoses, thinking could air leak in there be reason for vibration.The purge valve is on the inlet manifold, hiding behind the air filter box.
If your car is automatic may be you should check the CVT fluid level.
Vibration on acceleration on B class sometimes is caused by the transmission, not drive shafts.
Have you replaced the control unit with the gearbox?Hello I have changed both driveshafts and i just installed a brand new cvt gearbox. The wombling at acceleration from 20 to 90km still remains but with smaller left to right duration now. But its not from the gearbox since its new. So now i will try the new sparkplug wires since the sparks are new. I will update further.
