1 - 1 of 1 Posts
I have a problem with the supply from the heated seat controller to the left hand seat heater switch.Supply to RH switch is OK i.e 12v. The controller was water damaged and it's possible caused a short/fault with the section of the wiring loom that connects to each of the heater switches and appears to be joined under the lower console tray. I have disconnected the front and rear fastenings but it seems impossible to remove the tray because of the handbrake. 1. Is the cable joint under this tray and 2.is there a special way to remove the tray?
Thanks for any advice.
1 - 1 of 1 Posts
