C230 K Sport Sedan
Can someone explain what the difference is between Meguiar's Cleaner Wax and Meguiar's Paint Cleaner?
W-1-2-3 Go!
Cleaner wax has cleaning properties in it as well as wax for protection, while the paint cleaner is simply paint cleaner, and has no wax in it for protection.
Concentrations vary too. Cleaner wax has both cleaner and wax, so its properties as a cleaner and as a wax is 50% for each, as compared to the paint cleaner which is (I assume) 100% paint cleaner and has no wax.
So if you want to protect and clean at the same time, use the cleaner wax--easy jobs usually but half the job is done. If you want to purely clean, use paint cleaner, and then wax it with a separate wax for protection.
Hope this helps
