Hi ///s320, yes I bought Bosch spark plugs. I did not buy them from the dealership. I ...
Hi ///s320, yes I bought Bosch spark plugs. I did not buy them from the dealership. I bought them from a small local oem parts store (they sell the same stuff as www.thepartsbin.com). I compared it with my original spark plugs, and the Bosch part number matched exactly. They were about $3 cdn each.
To access the sparkplugs:
1. Flip latches to free the top of the airbox (highlighted in Green in attached pic)
2. Remove two bolts holding air intake in place (blue in pic)
3. Loosen wire out of the wire guide (yellow in pic)
4. twist the air-intake out of the way. The point where it is attached is shown by the purple circle in the pic. In my case, when I twisted the air-intake out of the way, it eventually fell free.
5. Remove 6 hex bolts shown in red in the pic. (one is not shown but is under the air intake), and pull the plastic cover off.
6. Underneath, you will see where the inline 6 cylinders are. There are "black boxes" on top of 3 of the cylinders. These are the ignition coils, and each one of them handles two cylinders. I pulled the 3 ignition coils off (pull straight up, might need to jiggle it a bit to loosen it). These gave me access to 3 of the sparkplugs.
The remaining 3 cylinders simply have an ignition wire on top, I pulled these off. Note, in my case, the sparkwires seemed stuck and wouldn't come out. But after I twisted them (rotated them), I was able to pull them out using only my hands.
7. To access the sparkplug, you need an extension on your ratchet, and a standard sparkplug socket. When you put the new sparkplug in, the torque is stated on the packaging. It was well below the bottom range of my torque wrench, so I just hand tightened it (not very tight).
8. Put everything back together. To put the airbox back on (purple circle in diagram), just thump it a few times... it will hold tight...
Cheers
