1 - 10 of 10 Posts
1998 ML320
Does anyone have the MCS pinout for the MY2000? I have a 98ML320, did the MCS CD NAV upgrade, and now wish to add a phone kit for my Treo 600. However, I need the pinout so I can figure out what I'm doing - I searched the forums, and I know I 've seen it here before, but I can't find it.
Can anyone help me?
Thanks in advance,
Ian
BenzWorld Post Whore
10 E350 4MATIC
Here you go...
from Ken's website: <a href="http://www.keysolutions.com/M-Class.nsf/8178b1c14b1e9b6b8525624f0062fe9f/c090607b79d272a785256c4f0010a565?OpenDocument&Highlight=0,VSS&AutoFramed" target="_blank">LINK to MCS PINOUT</a>
1998 ML320
Discussion Starter · #5 ·
RE: Here you go...
Thanks!!
1998 ML320
Discussion Starter · #6 ·
RE: I am getting a Treo 600 tomorrow, what are U doing?
Installing a Seidio 2500M Car Kit for a Treo600 on a Kuda phone base. I will post the DIY and pix... I am using a cassette adapter in the MCS for stereo connectivity, but it has a speaker as well. I just don't like FM modulators.... Going to pull 12v from behind the 12v socket in the passenger well, nd run the microphone behind the MCS (or should I use the built-in? Has anyone done that? Or would the sound be superior from the included mic in the kit?) up the driver's A column.
1998 ML320
Discussion Starter · #7 ·
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
I have tried using the ML’s built-in mic and had no luck. In two different cell phone hands-free kits, the sounds was always better with the included mic. I even isolated the ML’s mic from the telematics system and it was still not good. I guess it is a difference in impedance, and I just never bothered to investigate it.
- RODNEY
1998 ML320
Discussion Starter · #9 ·
Done, here's the pix.
Install was easy, took power from behind the 12v outlet in the passenger well. The phone base is the Kuda phone base, $62.00.
Note, don't turn the volume all the way up or you'll get terrible feedback!
Ian
MBs
RE: Here you go...
S4toML - 3/3/2005 8:57 AM
That's a 2001 MCS as I recall. A 2000 MCS is a bit different. Here's the pinout:
http://www.whnet.com/4x4/MY2000_MCS_pins.html
1 - 10 of 10 Posts
