2000 ML430, 2008 GL550, 2008 Ford F250 Superduty
hi fellas. after i installed my new system i noticed that my navi is all wacked out. according to it, im in san gregorio, ca when im parked in my garage![:D][:D][:D]
i pulled the mcs out again and double checked to see if i forgot to plug in the antenna but everything seemed to be plugged in except this little square plug on the upper corner (grey box/tab).
when i plugged it in, it still didnt correct my location. i drove around the block to see if it would reset but i get nuttin.
does anyone know if there's a reset button on this unit that may fix the problem?
tia
2014 ML350 BlueTec
tsanjose - 3/6/2005 10:04 PM
tia
Unplug the negative terminal for about ten minutes, in an open area, free from overhead wires, that should re-set itself....make sure you have your radio code handy......
2001 ML 55AMG
10-1 you have some sort of antenna problem. Double check all your antenna connections.
thanks guys. do you know which ones is the nav antenna? what is the little grey plug on the upper right (if your looking at the back of the MCS)? i know that was unplugged for some reason. i messed with the coax cable on the lower left but im pretty sure it's connected.
