Hello,
I am here to take advise from you my problem is as below:
-I have MB S500 2004. Ihave no issue with the car so far. I noticed that my car goes down overnight from rear end both the sides. When i turned it on it will rise the car itself. But since last night we have temp. drop is very low it was below 0 F, Now what issue i have is that right rear sdie in very low left rear is not very low but when i i start the car it rise up left rear side but it won't rise up rear right side. What should i do? does it rise up when temp rise up to 20 F or i need to turn the engine on for sometime?
Appreciate your help and advise.
Too many to list
There are water droplets in the air shock system . When it gets very cold these droplets freeze and prevent the valves from fully closing or opening . Once you warm the car up by driving or daylight it should be fine
to fix this issue you need to remove the water from the air lines by adding new desiccant to the pump or just replace the pump entirely with a new one , see here
Hi,
My question is can i drive with rear right side is down? i already parked it today in sunlight. Will it damages other thins if i drive like that?
Too many to list
After you drive it a while , the ice should heat up and melt by itself and your car should come up to the proper height
As long as it’s not rubbing the tire you can drive it
Thank You So much for your help and your advise it did work, after driving for a while it came to its normal position. So is it normal to happen in cold or do i need to take care with something?
2000 S430, 2003 S430, 2000 S500, 2003 S600 TT, and 2005 E320 CDI
It's like tusabes said. Time to replace the dessicant in the air pump. Probably a good idea to replace the pump's air input filter, too.
Too many to list
