Hello,
My ML makes a little bearing noise. It seems to be drive shaft central bearing support. I already replace both back wheel bearings. I checked the drive shaft center support bearing and has a little play. Is it normal that have some play or need to be replaced?
Anybody can help me?
Thank you very much!!!:confused:
The bearing itself should have no play, the bearing assembly will however will feel like it has play inside the driveshaft center bearing housing. If you do change it you should do the u-joints at the same time.
