1 - 13 of 13 Posts
Zotye Auto 1.5T T600 2016
The best place to allow sea foam into the manifold is by disconnecting the purge valve and injecting via this pipe, with a warm engine. If you are not sure of it's location take some pics of the engine bay and I will point it out.
S550 4-Matic
Here are pictures
S550 4-Matic
I think I found it this hose goes straight under MAF sensor can u confirm that it is the right hose to use thanks!
No that is the engine breather pipe. Take pictures around the engine bay and I will point it out.
Can you get a picture of this area?
Yes this is the purge valve;
Discussion Starter #12
Yes;
1 - 13 of 13 Posts
