2005 ML350 Special Edition
does anyone know what are the wheel ranges for a ML350?
rim size?
rim width?
offset?
will 20x10 all around fit?
thanks in advance!
03 ML350
According to the 03 manual, widest stock rim is the AMG 9x18 with 52 mm offset. Standard 350 & 500 rims are 52mm offset. The optional 350 and 500 rims are 8.5x17 with 47mm offset. My factory Evo IIs are stamped ET47 and my base 16" I use for snow tires are stamped ET 52.
Based on the optional wheels, it appears MB is OK with a little less than 52mm offset. Inside clearance will probably the main concern going wider. Depending on tire, you might need to go down to around 40mm offset.
ML 270 CDI
rim size?
rim width?
offset?
thanks in advance!
I've had 22"x10's and have 20"x10" all round with out any probs. The both had 295 tyres and only rubbed on the back on big depressions in the road surface and fully loaded, but then it has been lowered.
Thanks guys! that helped me alot!
and nice ride DETANE
if anyone else has any pics of 20's or 22's on their rides pls post. cant decide if i want 20's or 22's
