does anyone know how to find out how much more current i can add to my electrical system without harming it? the manual and the alternator itself both say 55amps, im not sure if thats the hot output, the alt is the stock bosch on 83 300d turbo
I don't have the answer, but would like to know! I've run laptops off of inverters in the past, but on much newer cars. I've got an '82 300td and don't want to hurt it!
What would you like to run on your alt? My friend has a 98 VW GTI. and that puppy only puts about 55 - 60 Amps. And he has 2 12's Single Rockford 500/1 amp. And a aftermarket headunit. And his car still runs fine.
Hi guys,
I am new to the forum and also searched the info I need, however I need some help in my situation.
I live in New Zealand and here is my story. I imported a Jap version of 2008 C200 W204. I managed to get into the engineering mode and changed the region to Europe and I managed to get...
Hi Folks, recently purchased an A45, really enjoying the car. Just having one problem with the Blueooth connection. Hope someone could show me what I am missing!
Settings > Activated Bluetooth.
Under Tel, I can see Connect Device as per the instruction manual, but I am unable to select...
Hi all..
My Mercedes E class coupe 2012 W207 rear tail light (on the boot lid) is not working ..
First of all I’ve tested all the fuses in the boot/trunk.. they all have continuity ..
secondly, all the rear lights work when footbrake is applied except the tail light. I have also tested...
My CL500 2001 with command system is acting crazy - the tape flap opens when you start the car and will do this 3 or 4 times when you drive away and beep each time - it will not accept a tape either - has anyone come across this or even better a fix for this? :)
