Many MBZ, Couple of 911s, couple of pick ups
Hello,
The master window switch module on my 2007 GL320 CDI is in need of replacement. One window switch popped off and the rear window lock has become stuck in the down position. My question is do you need to remove the door panel to replace the switch or can it be pried up and replaced?
2007 GL450
Have you tried pooping the switch back into the spot again. They have one small grip on each side of the buttons that should keep it in place once pushed back into place. As far as the one stuck in the down position. Is the button stuck that way or is it just the window? Pictures would help. I fixed my putting after the buttons came off. That is why I am asking. There was no need to replace the console.
2012 GL 450 4Matic
Hello,
The door panel needs to be removed.
