1 - 19 of 19 Posts
W163, 1999 ML430.
I have a huge oil leak. It runs through about 2 quarts a week, and leaves a huge puddle of oil when parked. I replaced the valve cover gaskets, and this leak appeared immediately. It no longer leaks from the valve covers, but I am at a loss on what is causing this big leak. Timing cover? Front main seal? Any help would be greatly appreciated, as I have had to park it for the last couple of months.
Dallas, Texas
W163, 1999 ML430.
Is it on the front right side of engine?
W163, 1999 ML430.
Yes. As you look at the engine, it's on the left side. I am pretty sure that is the right hand side?
Dallas, Texas
Disconnect battery, remove alternator, clean area. Wrap alternator cable with electrical tape so it does not short to ground. Connect battery and start engine. Watch chain tensioner area.
2003 ml500, 2004 ml350 2005 ml350 SE 2022 F150 XLT
Discussion Starter · #9 ·
Ok, I will do that when the rain here in Washington decides to not be a downpour. I will go to auto store and buy a bunch of brake cleaner to see new leaks.
Dallas, Texas
Get inspection mirror while you at it.
Here is picture of oil pressure test port.
The test port is at high pressure so my thought was maybe it was spraying in a stream and hitting the area in question.
A valve cover leak is at low pressure, after the oil has been pumped up. So it would need to be very signinificant leak to loose oil at your rate, wraped, not torqued to correct Nm or in correct pattern. and you see no leak.
Look at this part 6 of an 113 engine rebuild pay attention at the 11:00 minute mark. It is here he reinstalls the timing tensioner. you will get a crystal clear view of what witek is thinking. The video series is so good I may watch all of it. Look for any cracks.
here is another on more common leak areas
Rain stopped here for now, had quite the storm this AM. Thunder storm at about 7 AM. Very rare I don't think I ever remember one happening first in the morning like that in Boise.
Discussion Starter · #13 ·
Thank you! I will watch the whole video also. I too the battery into the parts store, as it wasn't taking a charge from my trickle charger. Turns out I need to replace it. So I will be getting a new battery for it tomorrow. I bought brake clean, and more oil. So I should be able to get a look at it tomorrow, barring the downpours we had here today. Thank you for your advice, as I am at my wits end. I spent close to $1,500 on replacing coils, wires, plugs, intake pipe (because the clip broke off the intake when I removed it), valve cover gaskets, O2 sensors, and tires. And then it just stared leaking oil so badly. So I am enjoying my 35mpg 2019 Honda Civic ex, but I miss having a V8! I tore my rotator cuff shortly after all this, and am just now getting strong enough to do my own repairs again.
2004 CLK500 (Wifes), (2) 2005 ML500SE, 2004 ML500, 2000 ML320, 2002 ML320
I reviewed my hand written notes on the 112 and 113 engines we have in our W163's. I have read
that the chain tensioner bolt can leak somewhere, sometimes major leak. It is located behind the alternator, in the front timing cover,
and has a large hex head. you might want to look at that, but you have to remove alternator.
If it is the tensioner leaking you will need a new crush washer. Advance auto has a pretty good stock of generic ones in various sizes they may have the one you need today, I buy the ones for the oil pan plug there. Other wise dealer or on line.
Downpouring here now we got an 1 “ yesterday, the whole month of June we get 3”, Seattle must be drowning!
Discussion Starter · #17 ·
Thank you! I will focus on that today!
Discussion Starter · #18 ·
Thanks, that's great to know I can source it locally!
Dallas, Texas
1 - 19 of 19 Posts
