2001 SLK 230
Used this product years ago when I would rebild an engine...haven't thought of it for quite a while. Copied this information from a blog this morning..
"He suggested that I put 6 ounces of Marvel Mystery Oil in the gas tank every time I filled the tank. he said that it would give me better gas mileage and help the engine run smoother and extend its life.
Being a skeptic about such claims, I took his advice with a grain of salt. Nonetheless, I decided to try it. The worst that can happen, I figured, would be a few dollars down the drain; on the other hand, if it works, it may be good for my car and my wallet, too!
Now, at this point, I must put a disclaimer. I have no financial connection whatsoever with Marvel Mystery oil, nor do I own any stock in this company or have a gainful employment with them. Neither does anyone in my family.
After I put the first 6 ounces in the tank when I filled up, I forgot all about it until I went for another fill-up. Being a finicky record keeper, I keep a meticulous record of the miles I get per tankful of gas on all of my 4 cars. At the time of fill-up, I noticed that my car got 60 extra miles for the tank of gas. I thought that my driving habits got better, there was less head wind, I probably inflated the tires just right, etc. etc. I figured another tankful would even the things out. But next tankful gave me similar results. Then I tried it in my other cars, one after another.
The results were the same - an average of 60 to 65 extra miles for the tankful. The cars seemed to run a lot smoother, too! I picked up a couple of quart bottles at less than $4 each!
Things were getting interesting! For about 65 cents worth of Marvel Mystery oil, I was getting 60 to 65 extra miles. You just couldn't beat that!
Being a Physicist, I had to know the reason why this was happening. So I started digging deeper to understand this. What I found out made a lot of sense.
Inside a car engine, a tight-fitting piston moves inside the cylinder. This piston has 3 sets of compression rings that prevent the combustion gases from escaping into the crankcase ( the tank that holds the engine oil). During the movement of the piston, the area of the cylinder near the top, between the top and bottom rings, does not get much lubrication. This causes friction, and therefore loss of energy. Translated, it means that we waste gas. Apparently, the Marvel Mystery Oil lubricates this portion of the cylinder, reducing the friction. This means that there is less wastage of gas, therefore better mileage! It also cleans the valve seats, reducing carbon build-up, and improves the compression in the cylinders, therefore helping burn the gas more efficiently.
When I admitted my skepticism and eventual acceptance of this additive to my mechanic (who also happens to be my friend), he just shrugged his shoulders and said that I should trust his judgment!
Ever since, I have been preaching the virtues to Marvel Mystery Oil to everybody I know, and they are getting similar results.
I felt I should share this experience with my friends on this blogosphere, with the hope that they can benefit from this and save money in this brutal gasoline warfare.
I found out something more about this company that makes it. This product has been on the market since 1923 - that is 84 years! - and THEY HAVEN'T CHANGED ANYTHING!
That says something about good old American ingenuity!
P.S. Some additional information:
All 4 cars were fuel injected, however the information on the bottle says that it works equally well with carbureted engines, too.
All 4 cars had high mileage, from 75,000 to 130,000 miles.
The information on the bottle gives specifics regarding warranties.
Labels: Better Gas mileage, efficient running of car engine"
2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 valve (destroyed). 2005 E320 new toy.
Actually the worst that can happen is that you lose your catalytic converter They are designed to work with gasoline, not oil. I would also have some concerns about the seals in the fuel system.
I also used Marvel Mystery Oil in my older cars, as did my Father in Law (he was a professional mechanic) and it worked just fine in the "Stone Age" engines we ran then. There have been some major changes in the way things are done now, and I would be VERY hesitent to use this stuff in a "modern engine" with all the EPA and other controls.
Clearly it's your car and you can and should do as you feel is best, but I'm not about to try something in a fuel system that can cost thousands to repair if I have made a mistake.
