mercedes E200 kompressor
hi have been looking on this site for help with a manual gearbox can find auto but not manual well i have a e200 kompressor 2001 and it is nearly at 100 thousand miles and wanted to change the gear box oil could anyone tell me if this is possible as my friends keep telling me it is sealed for life.
kindest regards
craig
1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Manual
gear box can be drained and filled.It has a drain plug and a fill plug.
:bowdown:
hi thanx for you reply i have been under car and found the drainage plug an refill plug does anyone now how many liters of oil these gear boxes take to fill someone has told me 1.8liters but would like to be shore before i do it.
regards
craig
Manual box
euro spec car should be in the capacity fluid section of your owners manual.
Or drain and measure the drained fluid.See diy for differental fluid change and my additional tip on a cheap pump to refill,so you can easily refluid the manual box of gears.
2001 SLK 320(222K Miles), 2002 E320 Special Edition(186K Miles)
Just a small tip - first unscrew the fill plug BEFORE you unscrew the drain plug. It's not a nice feeling to discover after you have drained all the oil that you cannot open the fill plug. :eek:
