1 - 16 of 16 Posts
1981 300D w/ Manual 4sp.
Does anyone have the dimensions for the shift boot frame as well as the shift knob hole?
I would like to replace my old worn boot and knob and I can't find any shop that says they work for my model.
Or maybe someone has a link to one that will work?
-NatE-
2000 W202 Mercedes-Benz C250 Turbodiesel
The boot is REALLY cheap at the dealers, less than $10 (in South Africa, at least). Gearshift knob is a little more, about $50.
However, what I did was to remove the inner thread (just cut away the old knob around it), cut it a little shorter with a saw and fasten it within a new knob. Just make sure that the new one you buy will accommodate this inner thread. Then simply screw it back onto your gear lever.
1982 240d, 2007 e350
You see, less than ten bucks! I don't know why I didn't check with Autohaus in the first place...
haha its a great site :)
W-1-2-3 Go!
Meyle? Be careful with Meyle, their rubber parts aren't as good. I've said this before, I bought a tie rod from AutohausAZ with the ends included. The brand was Meyle, I thought great, real cheap, plus free shipping, and German made! So I went ahead to have the alignment shop install it (the original one in the car was frozen).
I checked them recently, and lo and behold. The Meyle boots had cracked, while the older ones that weren't replaced were still intact! Yep, you get what you pay for...
karugs said:
...and German made!
Here's the rear window switches' box that I ordered. German quality? I don't think so! The icon on the switch itself is not too great either...but it's either this or a $50 OEM switch.
In the background is the wiring diagram I need to follow for my power window install. Can't wait to dive into it!
83 300d turbo, 79 c123 AMG
I wouldn't get that shift boot from autohaus. I replaced the one in the 81 300d and it is far too stiff and very difficult to clean. I'd say if you can get a german seller to ship, the leather ones found on ebay.de are awesome.
Boardmonger said:
...the leather ones found on ebay.de are awesome.
Leather? Those should be aftermarket boots. My OEM shifter boot is a soft plastic/rubber, which also has the moulded grips to fit on the center console. I doubt that a leather one will be able to grip the center console as the OEM one does.
But I might be wrong...
W-1-2-3 Go!
Febi made in China? :eek:
Just a warning. Did you get the cheaper window switches from Autohaus? They light up GREEN ...don't know what they had in mind! :rolleyes:
Yeah, I wasn't too impressed when I saw the 'Made in China' label.
They weren't the cheapest window switches - they were the ONLY switches at Autohaus!
New OEM-ones here in South Africa: $350
New OEM-ones from Sunvalley: $200
For the time being, I will have to make do with these switches. After my $1200 order and $147 customs fees, I'm rather broke. Maybe in a few months' time will I replace the switches with OEM ones.
The leather boot has a string at both the shift knob and another for the console so it is sturdy. It is aftermarket but I'd say its better than OE.
Mmm, are you sure?
I replaced my sister's 240D's boot, which was virtually destroyed by a gearlock, with a new OEM boot. The difference in gear changes was eye-opening. It's as if the boot has a dampening effect on the lever, resulting in a much better-feeling shift change.
I think it accomplishes this by the way it forms itself around the lever, which I don't think a leather boot does.
I would, however, like to see a leather boot. I replaced my gearlever knob with a leather one and I think, if the boot has the same effect as the OEM one, that I'd like to complete my gear lever with one.
1 - 16 of 16 Posts
