1964 Mercedes Benz 220S chassis 111.012, 2007 Mercedes Benz C230 Sport
Need help with my transmission: not shifting into 2nd gear. Shifts into 1st, 3rd, and 4th gears. On the column shift lever and 4 speed manual transmission.
I have replaced the 2 bushings in the steering column, the bushing in the shift lever on the column, the 2 bushings in the shift rods to the transmission. The shift rods to the transmission are not binding. I want to avoid taking the 1964 Mercedes 220S to the dealer to save costs. Does anyone recommend Your Mechanic.com This one is challenging for me. When I purchased the vehicle, the transmission mount was bent. This could have affected the internal gears ?
An update: I have replaced the transmission mount which I believe was bent by the front driveshaft coupling blown out.Yesterday I disconnected the shift rod from the transmission (1st and 2nd transmission levers) and manually put the transmission in neutral ( at the shift lever at column). Then I manually pushed and pulled on the lower shift rod and the rod did move forward and backward. I am assuming now that the 2nd gear does work. Could the problem be the shift rods ? They appear to be the correct dimension. Does it matter which rod I connect to the column shift ball connection ? This transmission has 2 shift levers at the transmission and 2 shift rods at the lower column. Thanks for your help ! I have contacted Your Mechanic. com with no replies yet. Paul
50 years of MB
I'm going to say that website is most unlikely to find someone that knows anything about older Mercedes.
Where do you live? There is a forum here for mechanics in each region.
I think you will be able to find you answer here.
CLK 280 Ponton 190B
Had similar similar problems with a 190 early 1960s there was a problem with gear selectors in top of gearbox. had it fixed by MB, apparently a small ball bearing had fallen out. Make sure engine/gearbox mounts are in good condition. If the engine drops 1/2 to 1 inch from original position it will screw up the gear change. I assume it's column change.
Thanks for your feedback ! Well , good news . I contacted a mobile mechanic in the San Diego area ( Eric's Mobile Mechanics). He looked at my pictures and the bent transmission mount and driveshaft coupling that I replaced myself. He sized up the situation fast. I have linkage issues. He re-adjusted the shift rod ( had to bend it a little) and adjusted both shift rods from the column assembly so the connections were within factory specs. Took him about 1 1/2 hours with an assistant and the transmission shifts into all gears. Now I plan to have a paint complete.
Discussion Starter · #5 ·
I am now preparing for a paint complete. This car has been a long term project for me as funds were available. I bought the car for about $ 400 and have put over $ 5000 to restore
the interior, engine, suspension. A lot of love and patience needed if you do it yourself.
I have learned volumes on car repairs utilizing the original manuals.
Your friend, Paul
