SLK 350
I just had my bodyshop install the smoked tailights I received from R171.co.
Everything and all the bulbs are working, however on the on-board computer, there is a warning prompting that there is a malfunction on the rear lamps.
I checked the bulbs from the stock lamps and everything is the same. The installation was also a direct plug in so I don't know what the problem is.
Any of you with similar experiences or know of a cure?
Thanks in advance.
SLK 350
something along the lines of:
rear right lamp malfunction, rear left light malfunction...
SLK350 AMG Sport
Could it be that the new one does not have a "rear fog" which we know that there is only one and it's on the left side?
SLK 350
nah, the new ones do have rear fogs and it works also.
malfunction is still not going away. i guess this is just a warning to those of you that want the change to the smoked tailights, as i cannot find a cure to this problem.
the dealer will obviously know you changed the tailights because of this. however, i dont know if they can void the waranty as this is an original mercedes part.
R171 200K
Pretty sure they should actually fix it for you under warranty since its just a swap over of original parts.
Do you still have the message when you put the old lights back in?
The only reason i could think why they wouldn't fix it under warranty is if you damaged something when swapping them over.
