11/02 ML320
The drivers door unlocks using the remote fine but wont lock (it will go: down, up, down, up and stay up) so i have to use the key, this locks it fine.
It was doing it yesterday (it was quite a hot day) but hasn't done it since.
Where exactly do you spray the wd40 is there a pic of where to spray?
Should i be using wd40 or something else, eg. silicone spray?
I've done a search but nothing came up.
Cheers
Chris.
Banned
It might be the SPAM removed or faulty electrical wiring that is causing the problem. I think WD40 is only used to prevent rust on your car. I think it is now time to replace it with a new part or a surplus part. Please let me know if you already fix it and how did you do it. I'm curious if WD40 can do the work. Cheers.
