The top circle is an oil catch, must be emptied of oil caught from PCV system periodically, usually done when cleaning the throttle body. The lower circle is the electrical motor housing of the throttle body, when oil is here the "catch can" is most likely full of oil and/or the throttle body in/out seals need replaced. Should be replaced when removing throttle for cleaning. Also, if catch can is full, intake plenum may be full of oil, Not literally, but if removed, oil from plenum will spill everywhere making a nasty big mess. If to that point of oil everywhere, the Oil separator and drip pan may need replacing, meaning the High Pressure Fuel Pump will need removed to access one bolt holding the PCV separator onto the back of bank one head. take special care, as the Fuel system is under very high pressure and is driven by the bank one intake camshaft. The buildup on the intake valves is from excess oil in intake, These are direct injected engines so no fuel in intake tract to keep the intake valves clean by washing oil into cylinders. Most will not attempt much of this work, and really should seek a reputable shop. But if you're handy with a wrench, there are some good vids on some of this work.
