My 2013, E 350 (58,000 miles) needs replacement of the left (bank 2), intake camshaft adjuster. By the way, I have already installed the recommended oil check valves in the engine block, and new chain tensioners for both banks during a prior project to address cold start engine rattle. I did not have evidence of a camshaft adjuster issue at that time. I now have a trouble code for bank 2 ( left) intake only. Trouble code is P002177. There is also a 2-3 second cold start rattle then the engine purrs like normal. Other than that there are no additional codes and the car runs great. I have seen a brief video and read two other brief forum statements that this repair can be done by front cover removal without involving the valve cover. I am planning to remove the plastic bulkhead, front cover, and vacuum pump on the rear so that I can access both ends of the camshaft.
I have concerns however.
#1: If I need more room in the rear, how difficult is it to remove the firewall insulation
#2: Is it safe to apply torque to loosen or tighten the center valve at the front while a helper applies counter-torque at the rear of the camshaft (using torx 60 bit/breaker bar). The torque spec for the center valve calls for 130 Nm, and I don’t want to risk damaging the bearing surfaces on either the intake camshaft or the valve cover.
I know the service manual calls for valve cover removal and use of lockdown bars.
I also plan to carefully mark the the existing adjuster, chain and reference point on block prior to removal, so that I can transfer the mark to the new adjuster, and accurately install and verify correct position of the new adjuster. I plan to rotate the engine at least two revolutions to confirm correct timing and double check the specified pulse wheel views (for intake and exhaust) through the position sensor windows per the service manual.
One final question: for the left bank is it easier to remove and install the chain tensioner using 40 degrees after ignition TDC vs. 40 degrees after overlap TDC?
In other words is there more slack from the rail adjuster and thus more wiggle room to get the tension either out or back in ( of course, I will compress the plunger on the tension and insert the pin to hold the plunger prior to re-installing)
Thanks in advance for your replies!
