1 - 9 of 9 Posts
1994 S600 Coupe, 1995 S600 Coupe
I got this part, #24 on the diagram below, p/n 120 158 01 73, that EPC says is a "Lock, lower part, left". I thought this is for the distributor cover on the left, but I can't figure out where is goes, or what it locks.
Here's a photo also.
· Banned
n/a
There are apparently two different style distributors...
...as discussed not too long ago (please see the discussion starting from post #7 here: http://www.benzworld.org/forums/w14...el-m120-engine-loss-power-4.html#post16054642 )
On my car, the distributor is enclosed in a housing that looks like this:
while the other design, as pictured in the attached file, has the housing going over the posts of the dizzy cap.
Which one do you have?
I do not recognize this "lock" and it is probably used on the other style cap (or has been lost on mine and I never knew about it).
Good luck,
Steve
I have your style, but the lock is for the other side according to the EPC.
They show the part number for the cover for the other style, but not for the lower part shown in your second photo.
You may be right about the lock. But I'd like to know for sure.
· Banned
n/a
The part diagram shows housing that is not even close to the design I have on my early-production coupe. I attached another picture, which I tried to enhance a little bit.
The close-up view is showing the bank 2 distributor and the housing (apologies for the dirt and grime -- this was how the car came to me some 2 years ago).
This should be the exact area where EPC puts the lock.
Notice the plastic going UNDER the whole dizzy cap. at least 3 inches wide, and compare with the schematic drawing.
BTW, my "locks" are metal tabs, but they go on the cover, not on the housing.
Steve
600SEL '93, SL600 '95, E55 Wagon '04
Hi guys
This lock is mounted on the drivers side only and its purpose is to hold the bigger powers steering hose in place. You can see it mounted on the pic below just over the Mercedes-benz stamp on the front timing cover :)
Discussion Starter · #6 ·
Thanks! With staring at your photo, and my parts, I finally figured out how it works. It mounts at an odd angle, but it snaps into place.
Jon
Sent from my Nexus 5 using Tapatalk
· Banned
n/a
Thanks much to both of you. It looks like I will have to get it with my next order.
Out of curiosity Jon, how did you know that you need to purchase it -- did the old one break while you're undoing the distributor cap?
Steve
Discussion Starter · #9 ·
I didn't have the covers on either side, and the lower part that the cover attaches to on the left side. I saw the lock on the EPC, thought I needed it, so I ordered it.
1 - 9 of 9 Posts
