Moderator
M20
I need to remove this plastic cover
unfortunately I dont have the luxury of tools right now as I will be removing these while at the office parking lot. Can I just pry these off by hand or do I need to remove the plastic cover running the length of the cylinder banks?
1993 S600 coupe (RHD)
if i remember correctly you take the central section out at the front - it just slides forward. then you can see the attachments for the areas you have highlighted. i believe they just clip in place on top and down the sides. but be aware when i did mine the plastic was a bit brittle so be careful.
Moderator
M20
the slide technique didnt work. the center piece is bolted in by a philips head screw. but just the same, I was able to do what I needed to do. thank you
