Been doing a lot of searching on this - I retrofitted the aluminum oiler tubes over a year ago and the car has been running fine.
Except on start up, when there is just a hint of knocking on one valve. It goes away after a minute or so, so I am thinking that it is a lifter that has leaked during the night. When that engine is warmed up, it is so quiet at idle it just purrs.
I'm using Mobil 1 10-40 (seems to be available only at Walmart for some reason. If that matters.
On the 300E and M103 I changed all the lifters which were in the rocker arms.
I am reading here that to access the lifters on the M119, the cams have to be removed.
So I am inclined to live with the occasional knock.
Any opinions? Any permanent harm being done?
