500E many W124 Wagon and R129 500s
hello guys I need a new fuel distribution unit (metering head)for a 1991 registered 500SL
Chasiss number WDB1290662F035735
I have looked at germanstar.net in the usa
which quotes the following Bosch numbers :
0438 101 015
0438 101 016
these are different to the number (0438 121 080) that a Uk supplier is quoting for the m119 500sl
does anyone know if these are interchangable as the uk item is a used one at only $90 dollars guaranteed .
cheers for any info forwarded ;) Al in the uk
hi ,
thanks poundy ;) the breakers must have quoted the part number off the main unit ,i have asked hime to get the number from the actual distribution block ,which should match either 015 or 016 .now you have confirmed compatability i can fit with confidence.
once again many thanks Al uk
