1966 200 1979 300TD 1991 560SEC Metris (1991 300TE-24, 1983 300SD, 2000 C280 in the family)
I have a chance to buy a set of camshafts from a Euro spec 560 SEC. I have confirmed with the seller that the cams have 117 17 on them and the 2 digit code on the back is 25. The service manual confirms this to be the "RUF" cam. Is this cam a viable performance upgrade for my USA spec M117.968. It will have tri-ys but is otherwise stock.
R.I.P. Never Forgotten
1983-2007 MB's
The problem with swapping cams around is there's still an unexplained gray area in terms of the US cars accepting such modifications gracefully. Euro cars used different EZL modules, had adjustable dials, whereas US fixed. Still a lot of questions in this regard.
Thanks for the reply. I have seen that and I am looking for a Euro ezl as well. By what I have searched on the threads, it seems that this is the correct cam.
560 SEC
I have the EZL dial and wiring available if needed John :thumbsup:
Not sure if you need the ECE dial too, but I have them both still...
