1993 W124 200E
Hi! I have W124 from 1993. It's M111 200E (136hp).
Cold starts are brilliant, rpms are stable at 1000. But after a few minutes rpms begin to fluctuate.
You can see this here:
These aren't massive fluctuations, but engine visually shakes and I can feel shaking inside.
I have new spark plugs, new wires, new air filter, new fuel filter.
I ordered new OVP relay and I'll try changing it. Maybe it will help.
What are your thoughts?
Being a twin cam engine, primary suspect is eco junk wiring (engine harnesses + throttle body). See link for more details.
Make sure you always replace the gasket whenever R&R'ing the throttle body to avoid vacuum leaks which will affect idle among other things.
PeachPartsWiki: W124 Engine Wiring Harness Replacement
As for the spark plugs, make sure you only use Bosch F8DC4 and nothing else. No exceptions. And be aware that your engine has a disposable ignition system which usually requires replacement of the 2 coil packs, 2 coil to plug boots, 2 spark plug wires and 4 spark plugs about every 150K-200Kms with spark plugs every 40-50K kms.
