trying to change out the water pump as it started leaking shortly after getting her started. I've managed to remove radiator, upper hose, shroud, fan, and all pulleys. i tried to find the answer but it seems that people say it works both ways. do I need to remove the crank bolt to remove the harmonic balancer? or do I just throw a puller on and supposedly the balancer just falls off? if the bolt needs to come out, how do y'all keep the engine from turning over? torque would be no problem as I have a massive breaker bar and even a pipe to fit over it. gotta love that 1 single bolt for the WP behind the balancer. lol. TIA
