1973 280, 1984 280CE,1985 300CD, 1969 Triumph TR6, 2004 Land Rover Discovery 2, 1990 Saab 900S
Car is a 1984 production date 280CE Euro Spec... The fuel pump relay needs replacing. Currently "jumping" terminals so the car will start.
My question is, the OEM Mercedes relay, part number 001 545 6805 has a list price of $416.49 with my discounted price of $272.00 from my local dealership. There are none in the US and they need to order one from Germany and could take up to 2 weeks to arrive.
Kaehler makes an after market relay that is for the Euro 280SE/SEL/SL and lists for $99.00, but it says E-Tacho and not M-Tacho. Anyone know what the E versus M Tachgo means?
$99.00 is much easier on the wallet than $272.00, but not if it won't work.
And is the OEM Relay worth the premium price over say a Meyle of Vemo brand? I can get those for around $120.00 from overseas.
MB OEM
001 545 6805
6650/min 6Zyl 12V
M Tacho
Kaehler
0015454305
6650/min 6Zyl
Yellow Font Plant
Product Technology Electronic device Tool accessory
1982 300CD; 2012 ML350 BT; 2011 E350 4M Wagon
Have you opened it up for a look inside? Perhaps a soldier joint had failed. Or a resistor. Could be something simple.
FB
I haven't. I just bit the bullet and ordered a new one from my local dealership. once I replace it I can open it up and see if it is something obvious and fixable to have as a backup.
· Outstanding Contributor
600 (3.200 mm)
The M-Tacho is for 123 with mechanical speedometer and the E-Tacho is for 126/107 with electronic speedometer. Both have similar wiring. I think the E-Tacho will work on 123 chassis, but idle cut-off feature will not working on 123 with this relay. If it will not work then try to disconnect pin #1 - it is for speed sensor.
Discussion Starter · #5 ·
With that information I am glad I popped for an OEM M-Tach relay.
