Update, the manual I have incorrectly states there are two M8 bolts. Studying the gasket set, there are four holes that pass through the gasket in that area. Problem solved. I hope this helps someone else.
I did not cut or break the chain to remove the cylinder head. There are a lot of steps to this, but in summary the chain tensioner is removed, the slide pins for the upper Slide rails are pulled out with a slide hammer. (Radiator comes out for this). The cam sprockets are removed and the cams positioned towards the back. The guide wheel comes out, Cylinder head bolts come out and the head will come off, chain intact.Great work! I need to do this on my M110. Could you let me know how you took the chain off? Did you cut it? Can I remove the head without disassembling the chain Thanks!
