1 - 11 of 11 Posts
1983 240d - 1985 300d - 1984 280sel
Anyone know how to tighten the A/C Idler belt on the M110? I did a search and could only find info for the diesels. Mine is slipping and making my idle super low and rough sounding. This is on my 280sel, but I figured it would be the same as the 280e's and ce's.
1979 280CE
To tighten the a/c belt do this:
Loosen the allen head bolt on the front of the pulley
Turn the 10MM bolt on the right side of the pulley clockwise until it is tight enough
Tighten the front allen head bolt back down
When did you get a M110
1979 280CE
^^^Got me.
I got the car last fall. I don't know exactly why it lowers the idle, but before it started slipping, it would do about 700 rpm or so in park, but it can barely manage 400-500 now. Also, should you be able to turn the 10mm bolt without loosening the allen head bolt? I couldn't find the right size allen head, so I just tried turning the bolt to see what would happen. It moves freely, but doesn't seem to do anything. BTW, do you know the size of the allen head bolt? Thanks!
the car wont run at 400rpms, and it would be even lower in drive, and even lower in reverse. does it miss at all?
No, its not missing. I know its the belt, because as I watch the engine idling, it will speed up to normal whenever the belt catches, but when it is slipping and the belt isn't moving, the idle goes back down.
1979 280CE
You can turn the 10mm bolt but it will not do anything other than put alot of pressure on the bolt and it may break if the allen bolt isn't loose.
1978 280ce euro found dead on Ebay
Have you tried removing belt and seeing what car does as far as idle. I am with viper on this don't see connection If anything it should slow down when it catches something else is affecting idle remove belt and see.
Discussion Starter #11
I tightened the belt (it's takes a 8mm hex wrench, btw), and its back to normal now!
1 - 11 of 11 Posts
