Hi,
I picked up 100k mile 89 300E for $500. It has sat for a long time and as a result, the car could barely move on its own power. CEL would flash intermittently as it would cough its way forward. I've so far replaced:
Today, I pulled the plugs to see how they look, and they were already a bit cruddy. I did notice that cyl 5 and 6 wires came out with barely any force, so I tried to re-secure those a bit better.
The car has always needed a bit of gas when firing up as well, or else it would just die. It almost feels rough/knocking, until the oil pressure comes up, and then it's fine.
No issues with cold/hot starts otherwise.
Any suggestions are appreciated.
Thanks.
- fuel filter
- accumulator
- tested OVP relay (functional)
- replaced spark plugs (basic copper NGK's)
- removed ICV and flushed it with brake cleaner to see if it helps start up issue
Thanks.
