Mercedes Benz W140 (300SE) 3.2L 1991 Petrol. Import from Japan with Lorinser Mod.
My head light low beam of the left side is not working? Parking light is working and high beam is working thought?!! What could be the reason.??
Discussion Starter #2
Duplicate post .... sorrrrrrrrrrrrrrrry
Always Remembered RIP
1991 560SEC AMG
If it's a US DOT sealed beam headlight, probably the low beam filament is burnt out.
I would replace the headlight.
Although since you are in Oman probably you have the Eurolights. I don't know for sure if the eurolight is set up the same way, but I would guess that a replacement headlight would fix you up also
YEs you were right, replaced the headlight and it is done! thanks man.
